RGB Picture quality
Discussion in 'General TV Discussions Forum' started by icap55, Jul 17, 2003.
  1. icap55
    icap55
    My tv (Sony KV32FX65) has only 1 RGB scart, At the moment i have the following set up.
    XBOX to SATELITE RECEIVER to DVD PLAYER to RGB SCART ON TV which enables RGB for all.
    I am using Good quality scart leads (Monster). will this method of connection reduce the signal quality of all connected equipment?
    ICAP
  2. Rolo Tomasi
    Rolo Tomasi
    Dec 13, 2002
    215
    +4
    There is a school of thought that each time the signal passes through a piece of equipment its quality is slightly degraded. Following this 'rule' your DVD picture should be as good as it can be, the satellite a bit less and the XBox a further bit less. You could try connecting each piece of kit directly to the TV to see if there is a noticeable difference.
    As a possible alternative to reduce the daisy chain, could the DVD be connected to another scart on the TV and output an S-video signal to it?
    Trial and error, as usual, is the best way of deciding what is best for you, using your own set-up.
  3. GAmbrose
    GAmbrose
    Jul 5, 2003
    997
    43
    Essex
    +184
    Do Sky digital boxes do RGB passthrough? I didn't think they did.
    Gary A
  4. fernando
    fernando
    If you are not interested in digital auido, Try to connect your Xbox throught Svideo to Scart 2 or 3 usin an AV adaptator and a good quality cable Svideo+phono to scart. I do this with my Play station and I get almost the quality of RGB.
    I Agree with Rolo tomasi more steps may cause signal degradation.
  5. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    RGB to S Video - don't you need a convertor ?
  6. fernando
    fernando
  7. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    My PannyTUDSB30 does..:smoke:
  8. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    And Pace ones do RGB passthrough also
  9. GAmbrose
    GAmbrose
    Jul 5, 2003
    997
    43
    Essex
    +184
    Someone on the DVD Forums gave me some duff information then :(
    Gary A
  10. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Joytech do an x-box lead that has the choice of RGB scart or 4pin s-video, as well as 2channel audio and an optical digital out! Fully loaded you might say. I connect my x-box via s-video to my tv and my dvd via RGB but still get 5.1 audio from my x-box.:smashin:
  11. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    Gary, i answered your thread on the dvd forum and said that my Pace passes RGB through the second scart. Maybe i wasn't clear enough ?
