RGB Picture is yellowish - faulty cable ?
Discussion in 'Nintendo Forums' started by mjw123, Sep 20, 2004.
  1. mjw123
    mjw123
    Apr 21, 2004
    1,300
    48
    +32
    Just tested the Joytech RGB + Optical cable on my xbox and the picture is nice and sharp but predominently yellow.
    Is this a fault with the cable or do I need to set something on the Xbox to tell it I want RGB output.
    On the non RGB scart socket the picture is full colour but not razor sharp as you'd expect.
    Any ideas what's happening here ?
  2. wod
    wod
    Sep 7, 2003
    196
    +3
    could be the cable or the tv but best to try it on another tv with the same xbox and you could try the cable on another xbox to rule out things
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    cable fault, only 2 colours connected.
    (very common fault in those 5 SCART into 1 SCART out boxes)
