RGB Over scart?
Discussion in 'Blu-ray & DVD Players & Recorders' started by CRIZMO, Jan 7, 2003.
  1. CRIZMO
    CRIZMO
    just wondering if a scart cable is fully wired does it always carry an RGB signal if it is being sent down it?
    Chris
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    yes, what a strange question!
  3. CRIZMO
    CRIZMO
    i didnt know if a scart cable had to be RGB compliant or something. So simple, i know :rolleyes:
    Chris
  4. SimonD
    SimonD
    Dec 24, 2002
    134
    16
    Basingstoke
    May seem like an odd statement, but...
    Just in case you didn't realise not all scart sockets are RGB enabled so the scart cable assuming it is fully wired, only carries RGB if it is connected to an RGB scart socket!
  5. Totalnoobee
    Totalnoobee
    Another stupid question.
    I have a 17-18 years old Sony 25" TV with only one SCART, does anyone know it then they were wired for RGB or only for composite or SVHS?
    I tried connecting my miniDV cam to it using a SVHS to SCART adapter but I only get B/W, if I use composite its OK. Can this be the adapter's fault or is it the TV?
    Thanks.
    Javier
  6. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Definately no SVId RGB is likely
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It's the TV.
  8. Totalnoobee
    Totalnoobee
    Thanks to all for your answers.
    If the TV doesn't accept SVHS through the SCART, untill I buy a new TV (which will be as soon as they sell a PS PAL with YUV other than the Panny, hopefuly a Sony or Philips) I'll have to keep it to composite.
    Javier
  9. MarkB4506
    MarkB4506
    Nov 16, 2002
    Glasgow
    +4
    Thanks.
    Javier [/B][/QUOTE]
    The reason for this is - the composite in pin on a SCART is also used for S-video luma. A composite/S-video SCART needs to be configured for one or the other using the TV menu. If that option isn't present then the SCART will not accept S-video.
  10. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    Not trying to be snippy but a scart cable doesn't have to be fully wired to be RGB compliant, QED make RGB only cables that are only wired for picture....................a confusing state of affairs for sure this scart issue :rolleyes:
