RGB output
Discussion in 'Blu-ray & DVD Players & Recorders' started by Comicman, Jul 3, 2002.
  1. Comicman
    Comicman
    In order for RGB scart connection to work properly does your player have to have RGB scart output? Also can the scart lead be a standard scart (good quality) or does it have to be an 'RGB Scart'?
  2. chenko
    chenko
    As long as the SCART cable is fully wired it will do anything...
  3. Comicman
    Comicman
    How do you mean fully wired?
  4. chenko
    chenko
    All pins in the cable are wired to each end :)
  5. Comicman
    Comicman
    But my player apparently has to output RGB, just having a TV that has an RGB scart socket isn't enough.
  6. chenko
    chenko
    well i was answering your second question then :p
    if the SCART is *just* RGB you need to use a device with a RGB SCART out. thou i have heard that non RGB SCART has worked thou, its a case of trying it...
  7. DaveP
    DaveP
    There should be a menu item to allow you to specify the output. You should find it in the setup menu.
    On mine there is a choice of RGB, S-Video or Composite. You shoul also be able to specify the type of TV you have in the same setup menu, ie: 16:9 or 4:3.
    Have you got a manual with it?
    DaveP
  8. Comicman
    Comicman
    I'm sure I have the manual somewhere. I'll have a look tonight. Thanks for your help. Just been out and got hold of an s-video and audo leads from Richaer Sounds, if it's no different they'll just give me my money back. Got caught in the rain and they gave me a brolly - there's customer service for you.
  9. Comicman
    Comicman
    Sorry I meant 'no' RGB output.
  10. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    What kind of player do you have, and are you sure it outputs RGB?
    If you're going on info from Richer Sounds, well... they're always sure, but hardly ever right (in my experience of course).
  11. Comicman
    Comicman
    It doesn't have RGB output - it is the Pioneer DV 340 I bought a year ago, they may have updated the recent ones. I bought an s-video lead in the end and the picture is superb, very sharp.
