J
Julie Winston
I have done a search on this question but can't find the answer:
I have a PS2 feeding into a switch box. It is only used for gaming, not DVD playback. The switchbox, Btech BT21 MKIII, has an RGB switch which needs to be pressed in to get the best out of the DVD & Ondigital box. Can I get a lead to bring the PS2 games output to the switch box in RGB format? Or do I stick with what I have got & use the RGB switch?
The bottom line is:when playing games can the PS2 output RGB. If so what scart lead do I need & where can I buy it.
thanks
thanks
