RGB output digibox
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Tasos, Dec 20, 2002.
  1. Tasos
    Tasos
    When I select the RGB output option on my digibox I cant seem to get teletext.My TV is a panny Tx25??..about 9 years old. The digibox is connected to AV1
    Is it normal not to be able to get teletext when RGB is selected?
    Thanks,
    Tasos
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    What are we talking about here: digital text services on Sky, or analogue teletext from your aerial?
    Digital text services are available in both RGB and PAL viewing modes (as you would expect). Setting RGB only changes the method used to send the video signal from the digibox to the TV. It does not affect which services are available.
  3. Julie Winston
    Julie Winston
    My Philips Ondigital box gives teletext on RGB. Have you the latest firmware?
    Julie
  4. Fernsehman
    Fernsehman
    You forgot to give us the MAKE and MODEL of your (presumably) Sky Digibox.
    There is a known fault on some Pace Sky Digiboxes which can cause the symptom that you describe. It's a factory repair since a chip must be replaced.
    Fman
  5. Tasos
    Tasos
    Thanks for your help...
    The panasonic tv is faulty on the RGB input...
    I tried the digibox (panasonic 30) with another TV and it worked fine on teletext.
