rgb or Y/C ?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tiberious, Apr 11, 2002.
  1. tiberious
    tiberious
    Posted this on the TV forum - thought some here may have an answer ?
    HELP !! ,RGB or Y/C ?
    Problem - I have a Philips IDTV which has 2 Scarts - the first is RGB and must be used for a VCR (I presume because the digital signal is sent as RGB ?), the second is Y/C and can be for a decoder/dvd etc.
    Now, my Vcr has Y/C input/output , or composite, but is not RGB compatible - is there a converter of some sort I can get to convert RGB to y/c and back again , so I can record and playback a better signal than composite ?
    ALL HELP APPRECIATED !!
    Steve
    is there a device that willconvert RGB to Y/C, and back the other way ??
    thanks
  2. Stupot43
    Stupot43
    Nov 21, 2000
    649
    2
    32
    Dudley, West Midlands.
    +81
    Hi Steve,
    There are several devices that will convert RGB signals into y/c.
    The one that has been tested by a sister mag. of HCC can be found at:
    www.rgbtosvideo.com
    But other sites to try are:
    www.keene.co.uk and www.lektropacks.co.uk
    The first scart socket (AV1) on your tv should be used for your dvd which should be able to output a RGB signal. You could loop this signal through your vcr as most vcr`s have this facility - but personally I would connect my VCR to the AV2 socket on the TV. this should be to accept a y/c signal.
    Hope this helps?
    Stuart:D :D
  3. tiberious
    tiberious
    Thanks Stuart - I`ll be checking out those sites.
    Unfortunately, if I want to record a digital channel, I HAVE to use SCART 1 - the digital signal is not transmitted on scart2 - so I can have RGB for my VCR (which wont accept it) , and S-VIDEO for my dvd player , which would prefer RGB !! - JUST CAN`T WIN !!!
