rgb or vga
Discussion in 'Cables & Switches' started by mattytinter, Sep 1, 2004.
  1. mattytinter
    mattytinter
    Jul 28, 2004
    27
    3
    i want to connect my cable box to my panasonic pw6, i can easily connect it via an rgb scart lead , or i could spend £120 approx and get a js rgb to vga converter, would the picture quality be that much difference with the converter box??
  2. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Popular opinion on this forum is that yes, it would be worth it. If the PW6 has a weakness it's that it's scart input board isn't /that/ good (or, at least not as good as the other boards if you know what I mean).
    I'm buying a PW6 soon and I'm going for the JS Tech scart to VGA route ....
    Zed
