rgb or s video
Discussion in 'General TV Discussions Forum' started by jelly, Oct 23, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    when switching between inputs on my tv which is the sign for a rgb input
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    depends on TV but ... is ofeten used or the letters RGB what is connected???
  3. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    SONY RDR GX7 ,SKY BOX
  4. FluffyHunter
    FluffyHunter
    I think the only way to tell if you are receiving an RGB signal on your TV is to check the Manual Set Up menu and see if the RGB Set Up option is available, whilst viewing the signal in question.
    RGB Set Up will only be availble if you are watching an RGB signal.
    Older Sony TVs used to display a different AV label when an RGB signal was detected (see below) but this seems to have been dropped on newer models.
    Hope that helps,
    Matt
  5. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    so why dosent it display a rgb signal instead of a simular icon but instead of 3 dots it has a s in the circle and a 2
