RGB or not RGB?
Discussion in 'TVs' started by keyser, Mar 21, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    I have a panasonic satellite reciever, and I noticed when I was going through the menu that I can switch between PAL and RGB. But I don´t see a difference in the picture. What does an RGB picturelook like when it´s connected to a scart input that´s not RGB conmpatible? I have a widescreen TV, should I set the receiver to widescreen or normal, how does this affect channels that are normal and widescreen like sky premier ws???
  2. Italo Tettoni
    Italo Tettoni
    Feb 25, 2001
    If your TV does not have RGB input it will automatically default to 'Composite' (or 'PAL' on your box menu, so set it there). The RGB picture is much better of course and it automatrically adjusts the picture ratio (if the TV station is sending the appropriate signal).
    Can your TV accept Svideo input (the next best option)? You should be able to switch the satellite box to output Svideo (usually through the video SCART).
  3. Doubledoom
    Doubledoom
    Make sure you have the scart lead plugged into the RGB scart on the tv. Usually, only 1 of the 2 or 3 scarts is RGB enabled.
    The easiest way to see the difference is to switch between PAL and RGB on the digibox picture menu.
    You have a widescreen tv, so set the digibox to 16:9. If you do not, you will not benefit from the anamorphic widescreen transmissions.
  4. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    Thanks a lot for your help guys. So I set my sat receiver to RBG and connect it to a rbg combatible scart input and set it to widescreen. So it´s normal when I switch to RGB and have the receiver connected to a scart input thats isn´t RBG ready then the picture really does nothing, just remains in composite. But how does the "wide" setting affect normal 4:3 and 16:9 broadcasts. I have always had the receiver set to normal and I guess then that normal 4:3 broadcasts have been stretched and I don´t know what goes for the 16:9 broadcasts??
    p.s. My TV has only one RGB scart, can I get an multiscart plug that is good quality and RGB ready?
  5. qfk123
    qfk123
    Mar 11, 2002
    994
    +90
    I had a similair problem with my old TV swtching to RGB, but try switching on The Scart control option , as that turned on the RGB setting
  6. Italo Tettoni
    Italo Tettoni
    Feb 25, 2001
    Keyser if the broadcast is 4:3 or letterbox it will show up at that ratio on the TV because they are brodacsting it in 'anamorphic' mode. The only programs to fully fill the screen will be the ones to be broadcast at 16:9.
    The only thing to keep an eye on is that some channels broadcast the TV ratio switching signal and other channels wont, so the TV might not automatically pick up the proper aspect ratio, but you can always put the TV in 'Widescreen' manually.
