RGB or CVBS
Discussion in 'Home Cinema Buying & Building' started by neilb1906, Dec 21, 2003.
  1. neilb1906
    neilb1906
    Ive got a Sony DAVSC5 connected via SCART to a 28" Philips TV. TV is about a year old, Sony is new.
    When I select the DAVs scart, the Philips detects a CVBS input. Should not the DAV be providing a RGB output to the Philips??
    When I select my cable TV box, the Philips detects RGB all OK.
    Ive got the DAV plugged into SCART2, which Im told is a RGB capable conector.
    Help plse, as RGB is better than CVBS, is it not??
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Can your sony output RGB? some only do CVBS and S-video!
    If it does RGB you want to use it!
  3. neilb1906
    neilb1906
    Thanks mate for reply.......Ive at last found the bit in the setup menu on the DAV to change from VIDEO to RGB.
    All is well now thanks
