RGB only scart cables?
Discussion in 'Cables & Switches' started by Pezerinno, Jan 15, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,420
    71
    Southsea
    +69
    Hi, if I want to use rgb scart from my freeview PVR to my LCD TV do I need an RGB only scart cable or can I use a regular scart cable? If I can use a regular scart cable is the performance gain worth the cost involved from scart to rgb only scart - they seem to be a fair bit more expensive.
    I'll be using optical out from the pvr to my yahama amp for sound.
    Thanks. Nick.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    You can use either type of scart cable. I'm not sure that I would go to the expense of an expensive RGB cable for Freeview but a reasonable quality individualy screened mid price scart would be a step up from the supplied freebie and is probably the stage where the laws of dimishing returns set in.
  3. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,420
    71
    Southsea
    +69
    OK, as I suspected. Thans Ian.
