RGB Only Scart Cable - Is it worth it?
Discussion in 'Cables & Switches' started by dboo, Nov 4, 2004.
  1. dboo
    dboo
    Sep 14, 2004
    28
    My DVD and Sky are presently connected to my TV by ordinary Scart cables. I understand that it is possible to buy Scart cable which only handles RGB signals rather than ordinary Scart cables which handle, RGB, S-Video and Composite.
    Is it worthwhile getting Scart cables which handle only RGB beatring in mind one would cost around £25? Would I really notice the difference?
  2. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    On a top quality cable it shouldn't make any difference as there should be sufficent shielding between the video & audio wires.
    On a cheaper cable, like your £25 example it should make a noticable difference, it'll be down to your screen size, quality of the source and your own fussyness level to how easy you can spot it.
    Obviously should is the important word there.
  3. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
    it did for me, have a couple of SQART 41** cables and the difference was astounding. Just got one of off ebay at a very good price too :D
