rgb on a sky digibox?
Discussion in 'Sky Digital TV Forum' started by keyser, Mar 21, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    I have a panasonic satellite reciever, and I notice when I was goint through the menu that I can switch between PAL and RGB. But I don´t see a difference in the picture. What does an RGB signal look like when it´s connected to a scart input that´s not RGB conmatible? I have a widescreen TV, should I set the reciever to widescreen or normal, how does this affect channels that are normal and widescreen like sky premier ws???
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +235
    You have to connect it to an RGB scart connection on your TV for it work.
    It makes a big difference to the picture (IMO).
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    You should set your box to 16:9. Many channels are broadcast in 16:9, others are 4:3 - they will appear stretched. Premiere WS is broadcast in 16:9 - if the film is 16:9 it will fill the screen - if it is wider then you will get black bars.
  4. Doubledoom
    Doubledoom
    There are also answers to your duplicate post in the tv section. Keep it to one section in future.
