Rgb loopthrough ?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by kirk grubb, Feb 24, 2002.
  1. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    Are there any sky digiboxes that have a second scart capable of giving my dvd player rgb signals ?
    I tried using second scart on my panasonic digibox but it displayed no picture on dvd.
    CHEERS
  2. Doubledoom
    Doubledoom
    All the sky digiboxes have RGB passthrough.
  3. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    How come i didnt get a picture on dvd then?
    Im using rgb capable scart cables.
    Turned sky digibox to standby .
    Configured digibox & dvd player to output rgb signals.
    :confused:
  4. Doubledoom
    Doubledoom
    I don't know.
    Have you checked to ensure you have the scart leads going into the right slots (ie plugging in the dvd into the vcr scart)?
    I currently have my PS2 plugged into the vcr scart on my digibox and i am getting RGB fine, as i should do.
    In the past i used to have my Sony DVD player plugged in there before moving over to component video.
  5. Boney
    Boney
    Oct 30, 2001
    Devon
    If you are putting RGB SCART signal from Sky to / through the DVD Player this may not have RGB passthough in which case you wouldn't get a picture.
  6. Doubledoom
    Doubledoom
    Just thought of one.
    Is the dvd being plugged into the VCR scart? If you have it plugged into the tv scart, you will not get RGB passthrough.
