RGB Issue
Discussion in 'Plasma TVs Forum' started by jrussell26, Nov 1, 2004.
  1. jrussell26
    jrussell26
    Sep 25, 2004
    37
    I have a Sony KDE-P37XS1 and have a problem connecting my Sky digital box in RGB mode.
    When I switch from PAL to RGB output (in the setup menu) on the Sky box the picture is fine and appears to switch into RGB mode.
    However whenever I switch Scart control on from the setup menu the picture turns yellow?? If I turn off the Scart control the picture returns to normal?
    Does anyone know what is causing this?
    PS I am using a Cambridge Audi 21 pin Scart cable connected to the RGB input on the KDE-P37XSI (AV2).
  2. jrussell26
    jrussell26
    Sep 25, 2004
    37
    Tracked the problem down to a Scart coupler with a loose connection on the blue output pin.
    NB Sky digi boxes will only output RGB if Scart control is turned on as well.
  3. FEBABE
    FEBABE
    Is that a fact! I have the same set up as you and thought it must just be me - I couldn't see a difference between RGB and PAL - but I have scart control switched off. Thanks for the tip.
