RGB into panasonic plasma
Discussion in 'Panasonic TVs Forum' started by turnergw, May 15, 2002.
  1. turnergw
    turnergw
    Well, I'm about to take the plunge and order myself a Panasonic TH42PWD4. Now all I need to sort out is how best to connect everything to it!
    Main sources of interest will be the DVD player, digibox and PS2. All of these have RGB output via SCART. My original plan was to buy the much respected scart-to-plasma VGA box from http://www.rgbtosvideo.com/. However, having just been browsing through the Keene electronics catalogue in search of some other cables, I notice a couple of other options:
    1) Scart -> 4*BNC - RGB connections + sync on composite.
    2) Scart -> 15 pin VGA plug
    Now I know there are potential issues with the composite sync not being strong enough for the plasma to lock on to it with the scart -> RGB+composite lead - and obviously the composite video input is lost doing this as well (not that that's much of a problem)
    Should I assume the same would be true for the scart->VGA lead? Whilst I'm sure that the VGA converter box will do a fantastic job, I'm reluctant to shell out the extra money for it if the same can be achieved with a simple cable.
    Does anyone have any experience of trying this with a Panny plasma? I'd be grateful for any advice ...
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Don't go here. Just buy the John Simm box. It is cheap, it works REALLY well and solves ALL your issues. These leads might split the sync up but still produce too little voltage for reliable longterm operation. You are looking to make yourself problems that are easily solved by the Simm box.
  3. turnergw
    turnergw
    Thanks Nic, I think that's the route I'm going to go. I guess skimping on connections is a bit pointless after the cost of the screen !
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,180
    The Borders
    +3,381
    Turnergw
    For sure go with Johns box - it works very well and is bullet proof as far as reliability goes.
    Also if you use the Composite input for your sync you cant then use the S-Video input on you panel - Panasonic only allow you to use one or the other.
    Best regards
    Joe
  5. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    where can these boxes be bought?
    Thanks in advance
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  7. turnergw
    turnergw
  8. encaser
    encaser
    Mar 15, 2001
    3,593
    Suffolk/Essex
    +1,207
    I asked John Sim about them and he basicly said it probabley won't do the job as Sky boxes often are too unreliable for a decent enough voltage to work - it's a 'cheap' option to a RGB box - from the scart pin.
  9. Panicsony
    Panicsony
    It can either use the SCART connector or a Wall wart (supplied).
  10. akash
    akash
    Feb 15, 2002
    90
    London
    If you are quite clever you and have an AV ampilfier that has component switching you can utilise these outputs to use RGB signals instead of buying the box :cool: which is what i do
