RGB interference On Analog Channels on Freeview STB
Discussion in 'Freeview & YouView' started by Kevo, Jun 9, 2003.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    I bought a Thompson DT1000 Freeview stb and it worked fine on my Mum's old Panasonic 4:3 TV in RGB mode.
    But I recently set it up on my sister's TV (again an old Panasonic TV, but newer than Mum's).
    When I set the STB to RGB and switch to any analog channels there is a 'rolling' picture of the freeview channel coming through.
    Switch the stb to composite and it's fine.
    The scart leads are fully connected 'out of the box' cheapo type but worked OK before.
    Any ideas?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,628
    48
    UK
    +25
    Sounds like the TV is crap and not RGB compatible
  3. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    It is RGB compatible and gives a very good picture from the STB in this mode.
  4. Squirrel God
    Squirrel God
    Try moving the STB as far away from the TV as possible and make sure none of the STB cables are touching anything else (including the power cable). Does this help with the interference?
    It doesn't matter that the scart leads worked okay on another TV because each TV is different and sometimes signals do creep through, sometimes on pin 19. Do try another Scart cable but best if you could 'borrow' one rather than buying a new one, just in case it doesn't help :)
  5. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    Thanks SG
    I'll try your recommendations next time I'm round there.
  6. phenom2003
    phenom2003
    My (crappy) Goodmans TV does this. If it is in composite everything should be fine. Everything is affected by this be it DVD players, games consoles, STBs, etc.
    Solution, make her buy a new TV
    Richard
  7. lurcher
    lurcher
    May 15, 2003
    4,114
    Stalybridge
    +202
    Got the Thomson STB yest and on connecting got the same interference as Kevo did but whislt watching digital (rolling pic showing through). Was useing a freeby scart lead so swopped it to a bought (gold pins one) , prob solved.
  8. Kevo
    Kevo
    Aug 23, 2001
    5,363
    Manchester
    +146
    Tried a diff scart lead today but still the same :(
