RGB input into HS20 ?????
Discussion in 'Projectors, Screens & Video Processors' started by MysteryMan, Aug 18, 2004.
  1. MysteryMan
    MysteryMan
    Nov 18, 2002
    631
    Cheshire
    +32
    Just bought a Sony HS20 to be used with a Sky receiver.
    Spent last night trying to connect the Sky box's Scart output (RGB) to the HS20 and failed miserably.
    I have a Profigold lead of scart to 3 phonos and the PJ Multi cable.
    This is a very dumb question, but, I'll ask it anyway......
    Is RGB different to Component signals?
    I suspect that the lead I have is just getting the RGB onto different connectors and when I plug these into the Component inputs on the HS20 it can't make any sense of the signals.
    Help!!!!!!!!!!!!!!!!!!!!!!
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Yes unfortunately RGB is different to Component YUV. The sync on RGB from your STB is drawn from a fourth pin (the composite video output). If the Sony doesn't support RGBs (requiring a fourth phono on your cable and the ability for the Sony to combin RGB and Composite) then the easiest thing would be to get a JS Technology RGB to YUV converter. I've no experience of the Sony though so don't know if it works without the need for a converter. Anyone???
