RGB giving wrong colours
Discussion in 'Blu-ray & DVD Players & Recorders' started by Geoff, Dec 31, 2004.
  1. Geoff
    Geoff
    I've linked a Pacific DVD 1002 to a projector using a RGB scart lead but the colour on screen looks as though the wiring is wrong. I've checked the projector is correctly configured. My problem is that I don't know whether: the lead is faulty; the projector input is faulty or the DVD output is at fault. Any suggestions?
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    Need more info...What projector? What sockets? How many cables coming out this SCART RGB lead?
    What does the wrong colour image look like?
    Gordon
  3. Geoff
    Geoff
    Projector sanyo PLZ2
    Only sockets SVideo, Composite video, component Y-pb/Cb-Pr/Cr, DVI RGB/Component
    Only 3 cables coloured green, blue and red.
  4. Gordon @ Convergent AV
    Jul 13, 2000
    13,981
    +2,785
    OK.....The Y, Pb,Pr sockets are probably coloured Red green and blue but will that doesn't mean they accept RGB. They accept Y Pr Pb component.....
    An RGB scart lead would be expected to have 4 cables. Red, Green and Blue plus Composite video as that carries the sync signal that is required for it to work.
    If the DVD doesn't have component output then use s-video.
    Gordon
  5. Geoff
    Geoff
  6. Clarkey
    Clarkey
    Dec 27, 2001
    140
    Manchester
    you can get a toshiba 240 from RS for only £45 which can output progressive scan component. I'd say this would be a wise investment, after all the projector was expensive, you want to take full advantage of it.
  7. Geoff
    Geoff
    The toshibas as I understand it doesn't play DVD+, I'm looking for a good player whic can play both + an-.
    Thanks for your suggestion.
