RGB from Sky to Sanyo Z3
Discussion in 'Projectors, Screens & Video Processors' started by Tod, May 26, 2005.
  1. Tod
    Tod
    I have a Sanyo Z3 which I want to connect to a sky digibox using RGB rather than composite. I assume what I need to do is to use a scart from the digibox to the D-Sub15 connection on the Z3. However, I'm confused by the different types of sync. Looking at the relevant cables in Keene's catalog, there are three options - one wired for RGsB, one for Sanyo, and one for RGBHV. I assume I want the Sanyo one (which seems to be wired for RGBS), but it specifies that this is for the Z1 so I don't know if the Z3 is different. I'd also like to be certain that this is compatible with whatever is output from the digibox. Can anybody who knows more about this than I do (which wouldn't be too difficult!) help?
  2. sainthalo
    sainthalo
    Feb 24, 2005
    646
    19
    I ended up using S-Video instead and picture is fine
