rgb connectivity?
Discussion in 'Projectors, Screens & Video Processors' started by babyG, Jan 5, 2005.
  1. babyG
    babyG
    Hiya
    As a newby but not a thicky:)
    just got a toshiba mt200 and want to connect to it
    1. sky digibox
    2. dvd
    3. video
    All work great thru composit cable one at a time using breakout from scart
    My question is this----
    I am buying an auto scart switchbox which will merge the 3 into one. If instead of using a composit breakout cable, I use a componant breakout cable, will that work. (or RGB breakout - are RGB & componant the same?)
    If not are there any other options?
    I have both componant & s-video inputs on the projecter
    Also,
    if your interested, just bought an LCD wall mount from B&Q for £40
    It will work for a ceiling mount just by simply making a square metal fixing plate to the projecter. It will sit off the ceiling approx. 3" and will ajdust/tilt all directions:)
    Anyone interested, I will post model number
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Now *that* is a good idea! My home made jobbie is fine for now but I may want to improve it in the future, yes model no please. :thumbsup: ...PJ
  3. babyG
    babyG
    I am at work right now --- will look tonight:)
