RGB Connection
Discussion in 'AV Receivers & Amplifiers' started by DEO, Jul 2, 2002.
  1. DEO
    DEO
    Is there a big difference between RGB scart and normal cheap scart when connecting the Denon AVF 700 (RGB output) to a 6 year old Sony 29" trinitron?
    Instead of connecting DVD to TV direct and you use a 3 ways scart switching box will this definately degrade the signal and PQ?:confused:
  2. bob007
    bob007
    I would say there's a noticable difference, cheap scarts tend to be poorly sheilded.
    All depends on what quality the switch box is, you wouldn't connect a £50 scart to a £10 switch box.
    Where possible direct connections are always best, switch boxes and looping carries the risk of signals being degraded.
    Bob
  3. DEO
    DEO
    Bob 007
    Would the RGB scart give you better results even if it is an "older" T.V.
    DEO
  4. bob007
    bob007
    Even though the set is 6yrs old a decent scart should be an improvement over the cheaper scarts.
    If spending £40+ on the scart, connect directly unless the switch box is of the same quality to get the best results.
    Bob
