RGB connection to Panasonic 37" Plasma
Discussion in 'General TV Discussions Forum' started by Pip_UK, Feb 9, 2002.
Tags:
  1. Pip_UK
    Pip_UK
    The Panasonic 37" PDP has RGB/Component BNC connections - G/Y, B/Pb.R/Pr.HD.VD. (is this 5 BNC inputs?)
    Is there any way to run an RGB scart from an NTL Digital cable box to these connections to get an RGB picture?
    The tuner box with this PDP has rgb scarts but costs an extra £500 :mad:
    Pip
  2. AshF
    AshF
    Jul 1, 2001
    23
    I've got the 42" panasonic but it should be the same for yours. You can get a cable that takes RGB + composite sync from a scart connector to 4 bnc connectors. You put the RGB wires into the 3 componant inputs and the sync cable to the video in (composite). Then set the panel to RGB instead of componant and change the sync selector from HV to sync from composite. Got it? Or you could get an RGB to VGA converter from www.rgbtosvideo.com and do it that way. Any problems, mail me.
  3. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    I set up a friend's Pany 42" plasma using the RGB to VGA converter and the result is stunning, so I can personally recommend it.
    Simon
  4. NeilS
    NeilS
    Nov 16, 2001
    215
    Essex
    +8
    I have a spare 3m scart to RGB+Composite cable that I used to use with mine (gone RGB to VGA now), if you're interested I can do you a deal on it.
    Neil
  5. Pip_UK
    Pip_UK
    Thanks guys ...
    Have already spoken to John Simm.
    How much better is the picture quality with the RGB to VGA convertor? Is it worth the extra £200? (convertor plus leads)?
    I know that Sky compress their digital signal (MPEG2 presumably). I have been told that NTL compress this signal even further. Don't know if this is true but it might negate getting such a high quality connection.
    Cheers,
    Pip
  6. NeilS
    NeilS
    Nov 16, 2001
    215
    Essex
    +8
    I've noticed no difference in picture between direct RGB and the RGB->VGA convertor. I had to move to the VGA box as I wanted to use the component video connection for my new DVD player.
    Neil
  7. Pip_UK
    Pip_UK
    Thanks Neil,
    For someone who has only just discovered S-video and in awe at the PQ improvement, I think I will prolly be happy with the RGB connection.
    Cheers,
    Pip
