RGB Connection PAL-60 problem
Discussion in 'Xbox Forums' started by pablo99, Mar 21, 2006.
  1. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Hope someone can help me out.
    My XBOX360 is connected to the telly using a Microsoft Official RGB Scart lead.
    When in PAL-50 mode everything works fine.
    If I change to PAL-60 all is well, picture is fine, but......every approx 30-40 seconds the whole picture moves quickly to the right about an inch or so and then jumps back again.
    This happens on games and on the dashboard.
    I never thought it would be a problem and I'd just leave it on PAL-50, but now I see games coming which need PAL-60.
    Anyone seen the same happen with them?
    Pablo
  2. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    That's a strange one, maybe your TV doesn't fully support 60hz, how old is it?
  3. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Fatfingers73
    Telly is a Panasonic TH37-PE30 Plasma. I never had any problems at all with the PS2 on 60Hz.
    The picture is fine and fits the screen properly. Telly adjusts to 60Hz fine. Just this little jump every so often makes it unusable.
    Pablo
  4. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    Could the lead be faulty? Or connectors loose.Sounds like its loosing sync
  5. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    Does this happen on all the scart inputs? wouldn't you be better off using the component input?
  6. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Baldybouncer
    Suppose I should hope its the lead and not the 360 or telly. I hoped maybe someone else had the same problem and knew the cure. I'll have to try another lead. Pest is it's run up inside the wall :( and the telly has to come off to get at it. :rolleyes:
    Fatfingers73
    Sky works fine. PS2 works fine. Component Video input is used by the DVD recorder so is not available. I did tests to see if the difference between RGB and component was enough to move the DVD to RGB and connect the 360 by component, but I felt there was very little difference at all. Plus its not a HD set, so no real need.
    Anyone seen this happen with them?
  7. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    What I meant was have you tried the 360 in the other 2 scarts? One of the scart sockets on my old TV failed and gave me a jumpy picture.
  8. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Fatfingers73
    Sorry
    Never thought of that!!! :rolleyes:
    If I remember correctly two scarts support RGB. I'll have to try the other one. I hope it's not that. If it is I'd have to swap the DVD and the 360 around. I do enjoy the DVD having the component input and using progressive scan. I feel I watch DVDs more than I play games too.
    Pablo
  9. Burly
    Burly
    Nov 4, 2005
    249
    Lisburn or Uni of Bath
    +4
    on the topic, i have my 360 connected via RGB, but when i set it to PAL-60 im not sure it actually is setting it to that as i think my TV is 50hz. I read this in some user comments and in XBMC on my xbox 1 it says 50hz.
    is it possible to set it to PAL-60 and still have it display picture?
  10. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,145
    Bristol
    +9,890
    Once you set the 360 to PAL60hz, then that is what it will output. I dont think there is anyway for your TV to force the 360 to stay in PAL50hz mode unless they are smarter than I thought.
  11. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Update on this problem.
    Last night I connected the 360 to the front of my telly using the composite phono. Set the output to PAL-60 and.............it does it there too. :thumbsdow
    So it's not the RGB lead.
    Then I connected to my sons LCD from his bedroom using the yellow phono. Set to PAL-60 and.......it worked perfect. :suicide: So it's not the 360.
    Using two inputs on my telly and two different input types (RGB and Composite) means it's not the RGB scart AV1.
    So is my Panny plasma faulty? Can you imagine the shops response??
    "So Sir it works fine on TV, DVDs, Freeview and everything else for that matter, it just won't play certain XBOX360 games."
    :rotfl:
  12. fatfingers73
    fatfingers73
    Sep 23, 2005
    1,756
    North Weald
    +155
    Very tricky, how long have you had the TV? what store did you buy it from? do you know anyone with another 360 you can try on the panny?
    I personally would sell it privately and use the funds towards a HDTV (Just my tuppence)
  13. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Fatfingers73
    Hey don't worry I ran that one past 'er indoors last night. :rotfl:
    Her face kinda went :eek: :confused: :mad: :lesson: all at the same time.
    Fact of life is the sons LCD is a Samsung 940 and it does HD. Connecting it up last night we put the component leads in and watched the HD video that comes on the HDD. Then played PGR and Condemned. You can see the difference and I thought "gotta get a Panny HD set".
    Next step is a friend of my son has a 360. I'll try it just to confirm its the telly.
    Panny was bought from JL less than two years ago. Would sell it if I had to.
    Got the box, 5yr warranty, everything.
  14. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Just an update on this problem.
    I was told by the store Pal-60 will only work through the component connection. (Funny how you need the scart or composite to change to Pal-60???)
    I wired the XBOX360 with the component lead and sure enough it does work. :thumbsup:
    I think maybe it should work through the Official Scart RGB lead but mine didn't. Maybe someone can confirm theirs does.
    Anyway 360 now connected by component and looking good. DVD recorder now in through RGB and it looks fine too.
    Many thanks to all who helped. :smashin:
  15. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,145
    Bristol
    +9,890
    What store told you that because its aload of rubbish, I have been running my 360 through RGB Scart since launch day and never had a problem.
  16. pablo99
    pablo99
    Oct 15, 2004
    384
    Aberdeen
    +16
    Yeah I felt it was wrong too. Some "gaming expert" guy in John Lewis told me.
    The TV people in John Lewis are great, but they felt I should speak to the gaming dept because it was a 360 problem.
    Never mind all fixed and working now.
    Pablo
