RGB Composite Sync (Scart RGB) AV Amp
Discussion in 'AV Receivers & Amplifiers' started by r4nd0m, Aug 18, 2004.
  1. r4nd0m
    r4nd0m
    Hi, :clap:
    I've found you can't get AV amps with RGB composite sync (scart rgb) inputs and outputs, which means you have to drop down to s-video or worse still composite, has anyone found a AV which does RGB Scart? :lease:
    r4nd0m
  2. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Pioneer VSX-C301
    4 RGB scarts round the back.
    Not the last word in home cinema performance, but a solidly-built & well-equipped unit nonetheless.
    You should be able to get one for less than £175 new.
    DT
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,226
    2
    +3,713
    The old Marantz SR8/9300 had a Scart switch and the new shiny Arcam AVR300 can handle RGB signals by switching the component video over which is a pretty nifty trick. It is about 8 times as expensive as the Pioneer however.
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    The Arcam AVR300 can accept RGB signals on its component inputs with sync on composite. You need to get Scart-4 Phono Cables and 4 Phono-Scart Cables. These can be ordered as custom cables from QED. It will also upconvert composite and s-video inputs to RGB also.
  5. r4nd0m
    r4nd0m
    Great, thanks to you all, :clap: the Pioneer and Arcam look very interesting...your all shiny little stars.
    many thanks
    :smashin:
    r4nd0m
