RGB- Component
Discussion in 'Cables & Switches' started by smithir, Jun 4, 2004.
  1. smithir
    smithir
    Can anyone recommend a good RGB SCART - YUV convertor.
    I need the output from my SKY+ to be in component format
    TIA
    Ian
  2. jmack
    jmack
  3. smithir
    smithir
    Thanks very much looks promising.
    Could you give me any advice on the quality of component lead I should go for, I need one 7-8m longs and they vary from £50 - loads.
  4. jmack
    jmack
    i am i believer in getting the best cables and most you can afford. some people will not agree.
    each to there own.
    ps. what display you using?
  5. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    Look out for the banner ads at the top of the page as JS advertise there whose converters are highly regarded.
  6. smithir
    smithir
    My display is a Panasonic TH-42PWD6.
    I am thinking of buying the convertor you suggest and
    QED Qunex PCV Cable - £7.5 per Half Metre
    QED Qunex PCV Plugs - £50 Qty 6 - Fitted
    I am not sure yet whether I need to multiply the price per meter by 3 ?
    http://www.hifistore.co.uk/category.php?qsCat=CUSTCOMP
    Would the convertor give a better picture than running an S video cable same make as above via my amp straight to the display
    Ian
  7. jmack
    jmack
    yes it will.
    or if you are not using your vga input on the plasma the rgb to vga will give the best picture.
    why not email them at js/tech and see what cables they can supply for your budget
  8. smithir
    smithir
    Interesting this is one I have not thought of
    The plasma has a VGA input so could I come out of the AMP using an RGB to VGA lead? Is there anything I lose by doing this?
    Thanks again this is proving very helpful
    Ian
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    smithir
    As others have said the JS Technology RGB2YUV converters have proven themselves over and over and do a great job with RGB from a Digibox; pretty much every system we supply includes one of John's boxes
    Video cables do vary a lot in price - we supply four main brands that cover most budgets.
    The best value for money cable we offer being VanDamme - which are all custom made to suit each application.
    Using a 3RCA to HD15 to interface with the HD15 input on your PWD display works well - we keep a range of short cables in stock just for that application.
    A VanDamme Red Series 8m will work fine out of a JS Technology converter and wont destroy your signal - and wont cost a fortune.
    RGB converted to YUV will look better than S-Video - which is only available on some not all Digibox designs.
    Best regards
    Joe
