RGB compared to Component Video
Discussion in 'General TV Discussions Forum' started by Bristol Pete, Feb 8, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I realise that there is a difference.
    However, is it that noticable? I undetstand that component takes the picture from the disk (colour stream??) and results in a better picture.
    However, is there really that much difference between the two?
    Also, is it true that component improves region 1 pictures but can degrade a region 2 pic . ( I do not have prog scan).
    Finally should I let a set with component video in sway my purchase.
    Thanks,
    Captain Benefit.
  2. wanchaiman
    wanchaiman
    Here in Asia-Pacific component inputs are the norm. We don't have SCART or RGB (apart from a few Philips sets imported from Belgium).
    And all the DVD players here (again, except for a couple of Philips machines) only have component out.
    As far as I know RGB is just as good as Component to the naked eye.
    The "order or merit" (best first) is :
    Component/RGB >> S-Video >> Composite
    Go for progressive inputs though as this is where you WILL see a difference.
    Wouldn't it be nice to take the digital stream directly from the DVD player and plug it into a digital input on the back of the telly? Of course, DVD manufacturers dont think this is a very good idea at all. However China is manufacturing multi-region (Code free - not locked / nobbled) DVD players without macrovision installed and VGA outputs ... mmm:) Have a look for "Skyworth" on the net. The picture quality is astounding......
