RGB and sync on Composite vs YUV
Discussion in 'Plasma TVs Forum' started by MR2Harvey, Nov 15, 2003.
  1. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    I have found out that I can input RGB and sync on composite into the 400E.
    Which is best:-
    1. RGB scart to 4 RCA (RGB and sync on composite)
    2. RGB scart to YUV convertor?
    The first option is by far the cheapest and without further understanding should be better? It hav less leads in the system and no conversion. However is YUV better? and if so is it still better if it is just converting from RGB?
    What's your opions?
    Harvey
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    id say it would be better to go the yuv road, composite will degrade the rgb signal whereas yuv should not.
    personaly i avoid composite like the plauge.
    i switch my stuff via the amp with component out and it gives a better pic than using the composit out.
    Hope that helps
  3. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    The composite is just used to extract the sync pulses from, RGB is sent to the component input of the plasma.
    How good is RGB?
    Is it better to convert to YUV even if you have a RGB input?
    Harvey
  4. alwyn
    alwyn
    Dec 10, 2002
    562
    west country
    +13
    RGB is the best sgnal from the sky box. I use the scart to 4 rca comp. on sync with a 50 inch plasma and the PQ is first class.
  5. MR2Harvey
    MR2Harvey
    Sep 29, 2003
    460
    +6
    I was hoping you were goin' to say that :)
    That and the English victory has me in a good mood this morning :clap:
    Harvey
  6. scgf
    scgf
    Nov 16, 2003
    444
    28
    Market Harborough, Leicestershire, UK
    +25
    See my post in the thread 'RGB to Component losing sync!' - I tried both methods of connection with my Hitachi 42PMA400
    Anyone want to buy a JSRGB2Component converter?!
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Less conversion must be better. With DVD players with a choice of YUV or RGB it's not so clear cut, as you have progressive scan and it's ups and downs to account for. In my experience, the PMA400 is better with RGB, it doesn't do so well with YUV progressive. Gandley, harvey is spot on, but of course we all agree that composite as a video signal is a last resort, and used only to get the menu up and enable RGB and 16:9 aspect.
  8. ASH1
    ASH1
    Mar 1, 2003
    1,217
    +62
    Hi scgf, how much do you want for your JSRGB2Component converter?.
    ASH1
  9. scgf
    scgf
    Nov 16, 2003
    444
    28
    +25
    I have sent you a pm, ASH1.
    BTW, I will include Special Delivery in the price.
