My brain is frazzled at the moment
I'm planning to buy a Panasonic TH-42PH9.
Unfortunately connectivity is a slight issue & I'm not sure what the best solution is.
Basically the possibility exists to connect the Sony DVB-T receiver to the panel via S-video with a scart to s-video lead as the Sony has Y/C separation as an ouput option.
I was wondering if there would be a significant difference in picture quality between an S-video & RGB signal output, especially on a plasma panel like this ?
If there is likely to be a noticeable shift in quality I'll have to re-think the options
