RGB and Component and VGA
Discussion in 'Projectors, Screens & Video Processors' started by milanlad, Feb 19, 2005.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Hello
    Could some explain what is the main difference between Scart/RGB and Component Video?
    Is there any significant difference in quality?
    If my SKY+ or DVD player outputs RGB through the scart, and my TV has inputs for RGB/Scart, Component Inputs, and a PC-VGA Input, should I:
    a) use the scart/RGB,
    b) use a RGB to Component cable or converter if needed,
    or
    c) use a RGB to VGA converter
    Thanks in advance
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    RGB, as its' name implies, carries colour information discretely for each primary colour, Component (aka. YCbCr) carries it in a different way (not sure I really understand it, but it I think the RGB values are derived in the display from sums and differences of the 3 signals).
    Effectively they're the produce equal picture quality, one's choice is driven by connection available rather than one being inherently better.
    So, to answer your question: using SCART->SCART is easiest and won't be bettered by any other method.
    I think there is one important difference between RGB and component, I believe DVD players capable of 'progressive scan' (aka. de-interlacing) usually only output progressive signals via component .. but I don't think that's an issue for you here though.
