RF2 output with more than one box
Discussion in 'Satellite TV, Sky TV & FreeSat' started by finnie, Jun 20, 2015.
  1. finnie
    finnie
    Nov 7, 2007
    61
    In my new house I'm going to install two sky boxes on a multi room contract and send the HDMI outs to a 4 x 4 matrix. However for the rest of the Tvs I'm going to use the RF2 output so they can simply watch whatever is on one of the boxes. As we are able to tune the output of the sky box to a given channel (say 49) is there any reason why I cannot output 2 sky boxes in to the common house rf system and there for have two analogue channels (say 36 and 49) with sky on.
    Not sure if that sounds right
  2. logiciel
    logiciel
    Feb 2, 2008
    53,162
    UK
    +5,788
    There isn't any reason, and it is right!
  3. TJT1
    TJT1
    Jul 29, 2011
    4,828
    East Sussex, UK
    +1,139
    Provided the boxes have an RF out socket.
  4. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,991
    +1,176
    If not you simply add an IO Link or RF modulator.
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,620
    Redditch
    +4,208
    No real problem except for magic eye remote controls. To make these work you need one of these.
    https://www.cyberselect.co.uk/sites/default/files/custom-files/SPC4 Instructions.pdf
    Obviously you will need to find two channels that don't clash with your local transmitter (assuming you will send the freeview signals along the same cables)
  6. finnie
    finnie
    Nov 7, 2007
    61
    Now that is a cool thing I didn't know existed!
  7. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,620
    Redditch
    +4,208
    Only one input is required, either using the sPC4 combiner or chaining rf1 out of the first box to rf1 in of the second. Rf1 out of the first to the TV and rf2 out of the second to your amplifier. If you use magic eyes then only the second box will be controllable connected this way.
  8. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    You could always add a HDMI modulator for the other TVs, so they still get HD (if they have a HD Tuner)
    Seb
  9. Member 719122
    Member 719122
    Jun 1, 2015
    91
    London
    +11
    That should work but do your research as the HDMI 4x4 Matrix range in effectiveness - the Neet HDMI True Matrix does seem to get the best reviews at a good price.Good luck
  10. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Depends if you are using pure HDMI matrix or HDMI matrix over Cat5/6.
    If over Cat5/6 make sure its HDBaseT compatible
