I'm looking for a device and I don't know if it exists.
What I'm looking to do is to switch on a circuit when another separate circuit is switched on. In detail, turn on a light circuit via the standard faceplate switch and a transmitter on this circuit pings a signal to a receiver on the separate circuit which then switches on this second circuit.
I've been suggested a number of items - all of which requires the second separate circuit to be turned on via a mobile app or via a special switch unit. The scheme I'm trying to implement is for the user to turn on a light switch and two separate circuits turn on and then when the switch is turned off, both light circuits turn off. Only the first light circuit is attached to the switch. Hence why I require some means of circuit 'A' instructing circuit 'B' to turn on and then subsequently to turn off.
Is there any product out there that does this? Hopefully I have explaned it clearly.
Thanks.
Thanks.
