RF Splitter
Discussion in 'Cables & Switches' started by jpsboro, Oct 21, 2004.
  1. jpsboro
    jpsboro
    Please can you help, I am trying to split the TV aerial to feed two televisions. I have a splitter (1 male, 2 females) unfortunatley the tv aerial coming in is a male so how do I wire up ?? I can't seem to find a splitter that has 1 female and 2 males. What am I doing wrong ? Or what do I need ? Thanks
  2. simon123
    simon123
    May 14, 2003
    301
    +8
    use a female to female coax coupler to join the aerial and the single side of the splitter
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  4. jpsboro
    jpsboro
    Thanks, but I have a female to female coax but then the lead to the TV (TV needs Male input) is female so am connecting female(from splitter) to female(tv lead), how would I do that ?
  5. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    To fit two females together you need a double ended dildo, i mean a connector with male plugs each side! On the other hand, it's probably best to cut all the ends off and fit F connectors (only use a coax connector at the tv end) - while your at it, check if the cable is a decent thickness and has a decent amount of shielding, there should be plenty of braid and a copper foil layer. probably best to get some new cable eh? :)
  6. jpsboro
    jpsboro
    Might have to do that..........
    .....and I don't mean with the dildo!!!
