iamsludge
Hi all,
Currently I use either Sennheiser RS12 RF Wireless Headphones or my OrbitSound T13 sound bar when watching A/V material on either my little LCD monitor or my projector.
My A/V gear is not where the projected image is, it is off to the right hand side. At present I get much better sound from the headphones than the sound bar. Sometimes I have to use the headphones as I can't hear spoken word from the sound bar (and I can't crank it up too high and wake up the boy-child).
We are in the process of buying a new house and there I expect to be in a similar situation (still using a small monitor and a large projected image). The difference being that I'm thinking of having the LCD monitor in an adjacent room to the main room with the sound bar (as it might function better in a small room) and so need to think about audio solution for the room with projector in it. In this new room the A/V gear is likely to either be behind the seating position or to the right of it.
I don't want cables everywhere so am wondering if I can find any wireless speaker solutions that will receive the audio that the Sennheiser headphones receive?
I'm only looking for a cheapish option if one exists.
