RF Remote - It's Not Working!!
Discussion in 'Microsoft Windows' started by johndj1, Mar 27, 2006.
  1. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    I recently bought an usb rf mce remote control off EBay and I cannot get it to work (no sniggering at the back).
    I'm running MCE2005 Version 5.1.2700.2230 and the driver has installed fine (straight from the windows repository of drivers). There is no make on it, only a model number OR23E. Googling it brings back sites in German.
    Does anyone have experience of this? Am I missing something general about configuring MCE2005 to accept a remote?
    :lease:
    Dan
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    I didn't know that there was an RF remote for MCE. Normally they are IR. Does it appear in Device Manager?
  3. johndj1
    johndj1
    Oct 9, 2002
    190
    16
  4. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    I dont think that's an RF remote - it looks like the standard IR remote that i have. does the remote light up green for a start? Does the small red light come on the USB receiver when you press a button?
  5. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Errrrm, nope. The remote itself has a red light on it and there is no light on the usb. Soz.
    Don't say I've been swindled...:oops:
  6. Pudgerboy
    Pudgerboy
    Jan 5, 2006
    118
    i couldnt really say - the remote does have a red light on it but it should also generally have a green back light on all of the keys. it should just plug and play so maybe it is knackered.
  7. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Yeah, that's what I thought. I guess I should be more careful of german sellers on ebay.
    Ah well, thanks anyway.
    Dan
  8. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Not all MCE remotes have back-lit keys.
    Was it supposed to be new? They are very cheap from the likes of Ebuyer in any case.
    I have heard reports of them locking up which is cured either by leaving the batteries out for a few days or to more rapidly discharge the capacitors take the batteries out then short the battery connections with a paper-clip or similar.
  9. Vonzack
    Vonzack
    Jun 14, 2005
    127
    Leeds
    Did you get an IR receiver wit the remote or are you trying to use an existing one on your PC. The M$ MCE Remote uses a different frequency from other devices like iMon.
  10. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Nope, it's not IR, it's defo RF. There is no IR transmitter on the remote and no receiver.
    The seller has just sent me another driver to try. He says that about one in 50 do not work with the Windows pre-installed driver. I'll give that a go and let people know what happens.
    D
  11. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Just a postscript to this. Emailed the supplier yesterday and they sent me a link to download an exe which updates the driver. The result is that the remote works a treat from anywhere in the house pretty much. Nice not to have trailing wires for the IR.
    Just in case anyone else has this problem, the driver can be found here:
    http://www.jovs.de/download/setup_x10_mce_nov28.exe
  12. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Please could you post a link to this RF remote? It sounds like a really useful addition to MCE.
  13. johndj1
    johndj1
    Oct 9, 2002
    190
    16
  14. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Thanks for the link. Glad you got it working.
  15. newstuart
    newstuart
    Apr 22, 2004
    1,806
    Northumberland
    +84
    sorry to re-open an old thread, Im looking to get one of these and run an VGA extionsion lead from my living room pc to the bedroom. One problem i can think of is that if this will still work when the standard microsoft IR remote and receiver is still plugged in the pc for using downstairs?
  16. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    Good luck with this. Maybe I got a duff one, but my RF remote was not good and eventually went back to the seller.
    The idea is great. The RF receiver plugs into your USB port at the back and is near invisible. However, this was slightly marred by two things:
    1. I had to be pretty much on top of the PC for it to register a button push
    2. MCE does not recognise it as a remote when you're setting up the TV Signal.
    But, like I say, I may have got a duff one.
    Good luck, though.
    Dan
