rf quality
Discussion in 'Cables & Switches' started by AWA, Nov 5, 2005.
  1. AWA
    AWA
    Can somebody please tell me how to increase the quality of a rf (coax) signal and picture qualitiy without subscribing to any cable company? :confused:
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Using a low-loss cable might improve things - not cheap though and you would need to consider the effort required to install it.
  3. Member 32412
    Member 32412
    Jan 16, 2004
    12
    Seattle
    Well, antenna quality, of course, is a factor. If you're getting weak signal, or multipath problems, you might benefit from a more highly directional antenna. That can be problematic, though, if you're receiving signals from stations in multiple directions.
    On this point: in my experience, there's no substitute for a large, hefty, multi-element array antenna. Right now it seems there are a lot of antennae on the market with built-in amplifiers, designed for low-profile installation, and that sort of thing--I have never found any of those to work particularly well. Much as we'd like, it's hard to defeat the laws of physics...
