RF Output from JVC DR-MH30
happyhooker
With my old Panasonic E55 I used to be able to watch recordings on a TV in another room via the RF output and a signal booster/splitter. The JVC doesn't seem to allow this - any suggestions?
bsuttie
The JVC may not have an RF modulator built in which is what you require. Check the manual / menus for a modulator on / off setting. If it has one there is probably a channel selection setting as well. Just choose a channel that is unused in your area, i.e. away from your local transmitter's channels.
If the JVC doesn't have a modulator then you would need an external one, something like this
You could also use a VHS machine if you have one lying about
regards
Brian
