RF Out ??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Mo-S3, Mar 6, 2003.
  1. Mo-S3
    Mo-S3
    Jan 24, 2003
    92
    cheshire
    +4
    How on earth do i convert a RF signal from my cable box to an AV signal so that i can feed it into my AV amp?? The cable box has got not av connections, only RF IN & OUT. Can anyone help?
  2. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Must be an old cable box if it doesn't have audio outputs. It may be worth asking the cable company if an upgrade is available. Failing that, the only thing I can think of is to use a VCR to receive the RF output signal and use the output from that to feed your amplifier. If the cable box outputs NICAM audio then a NICAM VCR will output stereo which you can feed into your amplifier.
  3. Mo-S3
    Mo-S3
    Jan 24, 2003
    92
    cheshire
    +4
    If i feed the signal from the cable box to the video then wont the scart cable thatis connected to the av amp overide the rf signal?? The video is set to A1 on the channel select and it allows me to use the amp to switch between devices. if i tune the video to recieve the rf signal from the cable box on say channel 1 on the video, then how do i tell the video to send that signalthru the amp?? The video is a pnasonic by the way.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    If video is on and watching RF cable input,its scart should output that signal automatically, What sort of cable box do you have? is it an ntl analogue one?
    You will only get composite and (mono{I think}) though
  5. jim.rae
    jim.rae
    RF out by its very nature is mono and not at all suitable to feed an audio amplifier.
    You need to get a new cable box with stereo sound or nothing can be done.
    Unless there is a NICAM circuit somewhere in the system which can be used...
  6. Mo-S3
    Mo-S3
    Jan 24, 2003
    92
    cheshire
    +4
    Ive managed to get it to work, It is an old ntl box which im using for just a few essential channels, so im not too fussed about super dooper nicam digital etc etc
    cheers
