Rf out and digital switch
armitage5hanks
I have a RF out cable from a sky box, as well as a standard freeview coax cable.
Is there a switch that you can buy where there are 2 input cables, and 1 output cable and you can manually switch between the two to provide the feed to the TV.
I'd basically like to be able to switch between the Sky output which is analogue and Digital TV by flicking a switch.
JayCee
Normal practice is to feed the aerial into a Sky box and it is then combined with the modulated Sky signal and both are output from RF1 or RF2 into your TV's aerial input.
You would then select either via your TV's source button.
