RF Control of X10 from Pronto NG RU980
Discussion in 'Home Cinema Control & Remote Controls' started by PannyAdams, Jan 2, 2005.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    have been told that it is possible to use the RF transmitter inside my Pronto NG (European model RU980) to control my X10 lighting directly.
    However, the codes generated by Codegen (Set to Pronto/x10/a1/all lights on) with the pronto set to RF (0/0) fail to work.
    I assume this is possible because UK sites are selling RU970 CCFs that claim to do this:
    http://www.simplyautomate.co.uk/pro...isplay.asp?prodId=4737
    Can anyone help me with this please?
    Panny
  2. The Robman
    The Robman
    I think it's disgraceful that someone is selling a CCF file. If there's enough people that want it, you should all pitch in a quid and buy it, then give it to Daniel at Remote Central to post in his file section.
    Is there an FCC id on the back of your Pronto? If so, please post it as this will let us check what RF frequency it uses. If this matches the X10 RF frequency, we might be able to create the right Pronto hex for you. I seem to remember seeing a site somewhere that described the format of the X10 RF signals which shouldn't be too hard to Google.
  3. AndyCS
    AndyCS
    Jul 5, 2004
    78
    9
    Yorkshire
    Hi Panny,
    Yes its perfectly possible. I'm using my RU980 to control various X10 devices. House codes L1 through L6 are programmed in the attached PCF file. I know its not pretty but it is effective. Its also nice that the Pronto timers can be used to turn lights on/off when out of the house.
    Hope this helps
    Andy
  4. The Robman
    The Robman
    How do you open an "abc" file?
  5. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    will give it a go...all my devices set to house code A, but that is easily changed.
    panny
  6. AndyCS
    AndyCS
    Jul 5, 2004
    78
    9
    Yorkshire
    Rob, simple rename the file to remove the .abc extension
  7. norm2002
    norm2002
    Mar 7, 2004
    64
    London
    Hi Andy
    Just sent you this by email as well.
    You've given me hope! I just got an RU980 and have had no success at all in getting it to operate my X10 stuff. Been searching remotecentral with no success but found your post here. Set a couple of my devices to Housecode L1 and it works. :)
    Are you able to tell me how to get IR codes for other Housecodes or Unitcodes? I suppose I could change my general Housecode to L but, unfortunately, I would still need all 16 Unitcodes for it.
    Any help you can give would be very gratefully received.
    Regards
    Norm
  8. AndyCS
    AndyCS
    Jul 5, 2004
    78
    9
    Yorkshire
    Hi Norm,
    I use Codegen and I've sent you mail
    Andy
  9. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Andy/Norm
    What X10 gear do you have? It does work with the stuff I bought from Letsautomate.co.uk
    Panny
  10. norm2002
    norm2002
    Mar 7, 2004
    64
    London
    With Andy's help I've just got all my devices on my standard housecode working. So now I'm definitely going to keep the Pronto. :)
    Norm
  11. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Arghhh.....I meant to write its DOESN'T work with my X10 gear. What gear do you guys have?
  12. norm2002
    norm2002
    Mar 7, 2004
    64
    London
    I am using it with a TM12U and a bunch of LW10U wall light dimmer switches. I also have a TM13 but I haven't yet set the codes up for that.
    Norm
  13. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    I've just bought 3 of these: http://www.tlc-direct.co.uk/Products/VLIC1401.html
    not set them up with the remote yet (awaiting new pronto) but they work a treat.
    What's the difference (apart from £10 extra) over the X10 light switches: http://www.letsautomate.com/10030.cfm?
    Is it just RF/IR?? (also I notice the X10's only do 60 watt min)
    As i'd like to automate things in the house, but the X10 and wot-not is a whole new game to me....
  14. AndyCS
    AndyCS
    Jul 5, 2004
    78
    9
    Yorkshire
    I'm using TM13U together with various AM12, LM12, LW10
    Andy
  15. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Sorted......Just realised that I don't actually have an RF receiver :blush:
    I'd been driving them by and IR adapter (and thought that was broadcasting RF to the other devices rather than down the mains) - well you learn something about X10 every day!
  16. richard vriend
    richard vriend
    Oct 13, 2008
    hello
    I am looking for to the programm codegen is there someone where I can download that from .
  17. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    You have Mail :eek:)
    Stoobie
  18. shane0
    shane0
    Feb 25, 2007
  19. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    You have mail :smashin:
    Stoobie
  20. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    Perth, Western Australia (Originally Ireland)
    +226
    Sorry to resurrect an old thread but is there anyway of controlling UK/Aus (same frequency) X10 equipment with the inbuilt RF of a US TSU7000 ProntoPro?
    I know the US and the rest of the world use different frequencies, just wondered if there was a way.
    I have read that installing a IR7243 and using IR from the Pronto would work, but I would rather avoid this unless its a last resort.
    Any ideas?
  21. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Simple answer is "NO".
    There was a company somewhere in Europe advertising on the web that you could buy the 433MHz chip and get it soldered onto the board of the TSU7000 in place if the original chip. I can't find the link any longer.
    I can't even suggest buying US X10 stuff because that uses 310MHz whereas the US Pronto uses 418MHz :thumbsdow
    It is just sheer luck that the UK X10 and Pronto uses the same 433MHz :smashin:
    Stoobie
  22. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
    Cheers mate,
    So just to confirm - if I buy a UK/Aus IR7243 (or IR7243RF) to use with my 240v X10 gear AND my US Pronto, I should get everything to communicate then?
  23. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    Yes, that will work. The RF has to be of the same frequency, but the IR on the US Pronto will work the UK/Aus IR7243 (IR to X10 controller). It will also work with the IR7243RF, but only using IR.
    To complicate matters a little, some of the older UK X10 stuff used the 418MHz frequency so if you could find some of that you could do what you suggested right at the start.
    Basically, you have 2 options in getting the X10 signal into the powerlines.
    1. Use an X10 compatible IR remote and a gadget to translate the IR into X10 and put it into the powerline = Pronto (IR) and IR7243 (converts IR into X10 & plugs into powerline to deliver the codes) plus at least 1 X10 module to be contolled. [the top scenario in the attached diagram]
    2. Use an RF remote and a gadget to translate the RF into X10 and put it into the powerline= Pronto (RF) and TM13 (receives RF, Converts it into X10 and plugs into powerline to deliver codes. It also works as a simple RF on/off socket). You can add further X10 modules but this will work on its own [the bottom scenario in the diagram]
    I hope that helps
    Stoobie
  24. Markie Boy
    Markie Boy
    Dec 13, 2002
    1,260
    63
    +226
    Cheers stoobie, looks like the standard IR7243 it is then!
  25. quukske
    quukske
    Oct 17, 2010
    Can anyone please send me a working codegen to control x-10 on my pronto.
    I've searched several databases but all I get are dead links:mad::mad:.
    thnx
  26. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    quukske
    You have mail!:smashin:
    Stoobie
  27. nuff
    nuff
    Jan 22, 2006
    1,959
    Yate Bristol
    +81
    Could i get this too please stoobie:smashin:
  28. stoobie
    stoobie
    Jun 3, 2006
    444
    Exeter, Devon
    +78
    nuff
    stoobie
  29. BiggieBig
    BiggieBig
    Jan 3, 2004
    1,237
    38
    London
    +23
    any chance I can get this as well.
    I have a TSU9400 and I need the codes to control IR X10 Converter
  30. Jamie
    Jamie
    Jun 27, 2007
    4,412
    Harrogate
    +1,006
    The IR codes you need are here RC Files: Pronto Professional - Search (1)
    The codegen program allows you to generate codes for the older NG series remotes that could communicate directly via RF which is a different kettle of fish
