RF Arial connection to Composite
longyp
I have used the (v.useful) RF2 output on my skybox to pipe Sky to another room in the house.
I will view the sky using a projector.
The projector has composite,s-video and component inputs.
How do I connect the RF cable to this - what box of magic tricks do I need?
Thanks for any suggestions.
Reiner
You need a tuner/receiver for this.
longyp
Thanks for the reply.
If you have not guessed yet I am a novice at this and in the middle of building my home theatre.
I have just received my AV/Receiver (Denon 1906) so hopefully this will do the trick.
Regards
L
loadsofleads
Wouldn't it be possible to connect a coaxial connector on one end and a RCA plug on the other for a composite feed. Wouldn't be the best signal or picture in the world but it should give you a pic at least.
Reiner
Regards
I am afraid it won't work because AV receivers don't have an RF input for TV signals.
Since it's a Sky system I assume (not too familar with Sky) you would actually need another Skybox, see also my response below.
If the RF2 output is a true RF signal (as I assume) it won't be possible to do a direct connection since the signal is (RF) modulated.
Thus you need a demodulater aka tuner/receiver in this case to convert it to an AV signal (composite or better).
cbemoore
Your sky box only has one RF output, but it also has a splitter to split the RF signal to two RF connectors.
Why not just add a scart splitter, and split the RGB or composite scart output from your sky box to both your main tv and your projector?
Alternatively, does your Sky box have a composite output via an RCA connector as well as the scart output? That would save you buying a splitter.
Chris
