RF/Aerial Cables
Discussion in 'Cables & Switches' started by Frankie_D, Dec 20, 2003.
  1. Frankie_D
    Frankie_D
    Oct 19, 2003
    180
    Surrey
    Well all A/V cables are sorted on this new forum but what i need to know is where can i buy decent sheilded RF/Aerial cables since after tidying up the cables behind my tv, keeping power cabling away from them, greatly increased terrestial broadcast quality. The only place i can find is techtronics so does anyone else know some good retailers? Thanks.
    Frank
  2. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Frankie,
    I used Custom Cable Service http://www.custom-cable.co.uk and had them make some up using Van Den Hul VideoLink 75 cable and Insert Audio F-Type and co-axial aerial plugs. All my RF feeds for my TV, VCR and Sky+ use these cables and it works out at £11 per metre and £6 each for termination.
    Also have a look at IXOS XHV 200 (£25 for 1M), QED Qunex (£30 for 1M).
  3. bobbypunk
    bobbypunk
    The QED one works excellently
