RF 434mhz - 433mhz?
Discussion in 'Home Cinema Control & Remote Controls' started by AVMADMAN, Mar 30, 2003.
  1. AVMADMAN
    AVMADMAN
    just bought my new screen, and on the remote box it says that the carrier wave for rf is 433mhz
    i am moving to Ireland soon and want to buy an RF cabable remote, but on looking at the spec for all the new remotes they say they use 434mhz..
    will this be a problem or will i just have to have 2 remotes (1 universal and 1 that looks similar to a car key remote, which i am bound to loose!!)
  2. AVMADMAN
    AVMADMAN
    can nobody help me?????
