RF 2 on Sky info needed?
Discussion in 'Sky Digital TV Forum' started by Les E, Nov 15, 2004.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    Does anyone know whether the RF 2 out on Sky Digital feeds a stereo signal to other digiboxes/tv's?
    The reason I ask is if I distribute Sky across the house via a loft box/amplifier will this give me the same image/sound quality as if I was watching on my primary source TV?
    If not, what would be the best way? :confused:
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    The RF ouputs are both mono I'm afraid. :thumbsdow
    The quality of the RF outputs will never be as good as the output from the scart sockets (RGB or composite) but the quality is perfectly acceptable for feeding other sets throughout the house (portables etc.)
    Cheers,
    A. Dork
  3. GaryM999
    GaryM999
    Oct 31, 2004
    67
    Remodulated RF feeds are never stereo. There is no technical real reason why not just the expence of the kit required to do it.
    The best alternative would be to use a wireless video extender as these do often carry stereo signals. Or you could try cable extenders eg: Keene do a video to CAT5 (computer cable) converter which allows you to run longer distances.
