Hey. I had a very quick look, there's not a lot to work with having just single full range sweeps. It looks like your subs are something like 20-30dB hot which is insane. Even for me.
Some questions:
- How are you level matching your subs? Are you setting them all to 75dB each along with your speakers?
- Are you running Audyssey?
- How have you configured your minidsp with six subs?
Can you take the following measurements, with Audyssey off, all timing and EQ reset in the minidsp and the AVR:
- each sub, individually, on the LFE channel (4), with a timing reference
In fact, let's just start there. With that we can look at the time alignment to get the smoothest response.
You have a set-up like me with a pair of VNF subs. This changes things.
Usually the practice is to time align all the subs in the room, then apply the same EQ to the combined response (so the same EQ on all subs). This can lead to a lumpy response on individual subs, but the combined response at the MLP is smooth, which is usually all that matters.
That doesn't work for VNF subs though. It's no good having big humps and dips on the subs right behind the couch as it gives a weird feeling.
I'd be tempted to look at the four far field subs individually, time align them, then level match them and integrate them with the mains. Then I'd look at the two VNF subs as a separate sub, time align them and EQ them hard, ruler flat, and lower the gain. That'll give you all the TR in the back of the couch without disrupting the rest of the room. We can time align the VNF subs with the other four so that they don't ruin the response.
We can see whether that approach works once I can see the individual measurements.
Hey Conrad, thanks for responding here. I tried not to be long-winded but I do have some answers to your Q's:
1. - There was a video tutorial posted on an AVS thread that I used to help me with setting up everything. The video is from a YouTube channel called HomeTheaterGurus, I used his instructions on episodes 7 and 8 to level match and align my subs. Since all of my subs are identical I have the volume for them all turned up to the same point, the 10:15 position if it were a clock (or at a 3 on a 0-10 scale). And yes, I do have them set around 75dB when I run Audyssey. That being said, after I run Audyssey I implement what I believe is called a 'gain hack', which is to turn everything down in the AVR (trim, level, and sub adjustment) for the sub channel and then turn up the volume on the subs themselves to get it all back to where it should be. If the hack is legit and to be believed, then it's supposed to optimize the dynamics and punchiness of the bass and make the most of them.
2. - Yes, I do run Audyssey. After I have the subs aligned in the minidsp I run Audyssey using all the positions that it allows, and It usually ends up setting the 'virtual' sub distance in the AVR for around 25'. My plan is to upgrade my AVR sometime in the next few months so that I will have more flexibility to make more adjustments to what any room correction software would want to do for the higher frequencies. My Marantz SR7009 has been a great AVR but I don't have even the Audyssey Editor app that is offered for some of the Denon/Marantz AVRs to give myself more options (like setting a cutoff frequency in Audyssey so that it wont apply any EQ past a certain point).
3. - Configuring 6 subs with a minidsp HD 2x4 was a little challenging since it only has 4 outs, but what I did was use a Y-splitter for the 2 subs in the front corners and also for the 2 subs behind the couch, the other 2 subs are done individually. When I aligned them all, I started with the one furthest away, then the 2 VNF subs next, then the front corner subs and lastly the one elevated midway up the wall behind the TV. It's not 100% ideal, and at some point I would like to get a minidsp unit that can handle all 6 subs individually. I had considered upgrading to a minidsp 2x8 or 4x10 so I would have enough outs to do each sub individually, but, as with everything, there are pros and cons to getting a different minidsp unit. If you want the exact settings that I have set up in the minidsp for all of the subs (delay and inversion) just let me know.
4. - I will definitely get you the measurements you want for all of the subs individually with Audyssey off and the minidsp reset, and once I do I'll post the DropBox links for them here on this thread for your review. One question though, I'm not totally certain what you mean when you say for me to do it 'with a timing reference'; I may just be misunderstanding something obvious though, so judge me gently, lol.
With your questions having been addressed, I have some additional commentary as well. When it comes to the 2 VNF subs, they are less than 2.5' apart (close enough to be classified as co-located?) and are hooked up to the minidsp on just one output (using a Y-splitter to accomplish that). So, from my limited understanding I believe they act as 1 sub when I am doing the alignment process. The room is about about 25' going from front to back, and the 2 subs that are behind the couch are about 11' from the front of the room, so very close to being in the null that's supposed to be in the middle of a given room. In addition to giving some nice TR for the people on the couch, I thought that it may also help to mitigate the null by locating them there and improve the perceived response.
Integrating my subs with my mains is one of the next big steps that I planned on taking but I haven't done so yet, I'm still in the 'baby steps' phase of my learning curve, lol. I will say that after I upgraded my base layer of speakers to the GoldenEar, I changed the crossover to 80Hz and they sound like they blend together better now.
Before I got the minidsp I had just been splitting the LFE signal coming from the 2 independent sub outs on the Marantz for the 4 subs that I was using at that time, and when I was doing it that way I did indeed have the gain turned down a lot more on the 2 VNF subs. Once I got the minidsp and added in 2 more subs I level matched all 6 of them; I liked the improvement and they didn't come across as too overwhelming.
As I said before though, I only know enough about all this stuff to get myself in trouble and there is still plenty of work to be done on getting everything as good as is possible. Optimizing my room has been a long process... Over the course of about 4 years I went from having 1 sub and no minidsp and very little understanding about the home theater hobby to where I am now, so it's been quite the journey, lol.
