Finally got my UMIK-1 and MiniDSP 2x4HD yesterday via NLpost & Parcel Force, phew! Result though, no import duty or VAT to pay (hope no employee of HMRC reads this). So total cost was £270, result!
@Conrad. &
@MI55ION and anyone else that's interested. See the attached file for a quick comparison of the XTZ mic v UMIK-1.
Centre channel. Room correction off. As near as dammit the same mic position. Psychoacoustic smoothing applied. O degree cal file (UMIK-1), both mics pointed directly at speaker.
Not too much difference in the results maybe the UMIK is a little more sensitive at the upper end. The big difference was with the XTZ mic the AVR's main volume setting was at -5dB and I had to bump the mic recording level setting in windows up to about -20ish dB and still only got an average of about 63dB in the REW measurement. However using the UMIK-1, the AVR's main volume is at -25dB and the mic recording level is at -9.9dB and yet the measurement level is averaging about 75dB? Maybe something to do with the XTZ external sound card?
Any how, so far I have a lot more confidence in using the UMIK-1 for REW but will keep the XTZ RA Pro ll kit as it is handy for quick measurements like testing for room modes and I do like the RTA function. It's just a pain as it's an analogue connection to the AVR and you have use Multi Ch Stereo and physically unplug the speakers you don't want to measure, whereas REW over HDMI using ASIO4ALL v2 is a breeze being able to select an individual speaker on the fly.
Going to check I've got all the ASIO/REW settings correct. Then take a ton of measurements as I've got new seating and can better position all speakers, make sure the room treatment is correct and doing it's job, then get into the setting up subs using the 2x4HD.
Good use of lock down time me thinks
