Revolver, anyone got any?
TopMeTom
Anyone heard, got, any revolver speakers?
And using them in conjunction with home cinema?
Any thoughts?:smashin::thumbsdow
nuttyboyz
Yes,I run a pair of Cygnis:thumbsup: but I would really reccommend the AVF,they look first class,a stunning design they will please and pass the WAF,tunable bass also.The RW range are very punchy sounding,fast,tight bass,superb speakers.:smashin:
nuttyboyz
At the bottom of the AVF floorstander only,you will find a bass driver on the side,pull the cover off to expose the woofer and it has a link,remove that link and you get less bass,then you can shove them right up to the rear wall so that they don't take up much real estate.
TopMeTom
Where did you get yours Nutty?
I think I also read you can have the bass firing inwards or outwards, hoping to get a demo of them later in the week.
nuttyboyz
Experiment with posistioning like all speakers to see if the bass driver should point inwards or outwards,I would try inwards first.Give them a try,they sound great,Remove the tweeter mesh carefully,as this really effects the sound,and I preferd the dark Cherry models,lovely speakers that are overlooked.
