Reviews of Marantz SR7300?
Discussion in 'AV Receivers & Amplifiers' started by TheSeer, May 25, 2003.
Tags:
  1. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Anyone know of where I can read a review of the Marantz SR7300 AV Receiver? I'd be very grateful if anyone can post a link.
    I know this receiver potentially has a problem with a high-pitched noise (as discussed on this board), but I can get it for £450.
    thanks
    TS
  2. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I haven't seen any pro reviews but there is this over at HT forums.
    I had the SR7300 for just over a month. If you can get one without the high pitch problem or it doesn't bother you I think it is a very good reciever.
  3. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Hi Daneel,
    Thanks for the link.
    Did you return your Sr7300? If so, was it because of the high-pitch noise problem.
    TS
  4. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Yes I did return mine and it was because of the noise.
    Be careful if you do buy one as I don't think Marantz accepts this as a reason for a return and your dealer may not either. Apparently it falls inside the spec of the unit.
  5. Photo
