REVIEW: VIZIO Bluetooth Soundbar
Discussion in 'Advertiser Exclusive Offers' started by Studentcomputerscouk, Jul 10, 2019.
  1. Studentcomputerscouk
    Standard Member AVForums Sponsor
    Apr 18, 2019
    42
    11
    Birmingham
    +9
    What is the VIZIO Bluetooth Soundbar?
    The Vizio Soundbar is a 38” 2.1 Home Theatre Sound Bar with Wireless Subwoofer. The perfect addition to any small to medium sized HDTV, this sound bar connects easily to your TV with just one cable. The wireless subwoofer adds bass missing from your TV, all without the need to run any extra wires. Built-in Bluetooth allows you to wirelessly stream music from a smartphone or tablet, while Dolby Digital and DTS Digital Surround™ audio technologies turn movies, TV and games into an immersive audio experience.
    Performance:
    The VIZIO Soundbar is a huge upgrade over your TV's built in speakers. Dialogue is clear and crisp, sounds are separated beautifully. The bass is so strong that you will probably have to turn it down to avoid annoying the neighbours. The soundbar is loud without any distortion like most speakers, there is nothing more annoying than getting into a good song or movie and hearing the sound distort half way through. The powerful speaker truly brings you that cinematic experience inside the comfort of your home, perfect for family time, movie nights, parties and more.
    Buy Now:
    You can buy a VIZIO Bluetooth Soundbar here - Bluetooth Soundbar 100dB with Wireless Sub 38" Black 2.1 Home
    General Features:
    · Designed to fit any small to medium size HDTV
    · Premium speakers with up to 100 dB with less than 1% distortion
    · Wireless subwoofer delivers thunderous bass anywhere in the room
    · Bluetooth streaming - Stream music from your PC, smartphone, or tablet
    · EnergyStar compliant
    Specifications:
    · Sound bar size: 38-inches
    · Sound Bar Speakers: Left & Right Channels (each) – 3.0-inch full-range drivers
    · Subwoofer Speaker: 6.0-inch Subwoofer
    · Sound Pressure Level: 100 dB
    · Sound Bar Frequency: 50 Hz - 19 kHz
    · Subwoofer Frequency: 50 Hz - 100 Hz
    · Audio Decoding Technology: Dolby Digital
    · Sound Enhancement Technology: DTS TruSurround, DTS TruVolume
    · Wireless Range (Subwoofer): 60’ Line of sight
    · Bluetooth
    · Sound Bar Buttons: Power, Input, Bluetooth, Volume Up, Volume Down
    · Remote control included
    · Power Input: 120V 60 Hz
    Summary
    As TVs have gotten thinner and thinner, the speakers on the panels have only got worse over the years, really effecting the sound quality and volume. People like the idea of a sound bar because it simplifies the set up and avoids running wires everywhere, plus it enables you to work on a budget. The sound bar takes about 5 minutes to set up and it automatically pairs to the wireless subwoofer when you plug it in. The best thing is you can control the sound bar volume with the Vizio TV remote without any extra set ups or complicated programming steps.
    Buy Other Speakers
    Alternatively you can view our other speakers for sale here - Speakers | Deals at studentcomputers.co.uk
